Re: Super A Sickle Bar Mower A-21 / A-23 Question
Posted by gene bender on April 18, 2007 at 18:06:29 from (67.55.226.214):
In Reply to: Super A Sickle Bar Mower A-21 / A-23 Question posted by Mark (PA) on April 18, 2007 at 17:17:02:
if the ledgerplates are dull on the guards i would replace all of them. You also need a manual for the mower to see how much lead the outer part of the mower should cause if its leeaning back too far when mowing the material is going thru at an angle thus the outer point where the divider or also called headboard leans back too far it will not cut as good. keep sickle sharp and tilt the cutter bar. the manual will describe all this.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
