Re: HELP !! Farmall M won't stop overheating!
Posted by 49 Cubber! on May 14, 2003 at 18:40:03 from (206.74.216.2):
In Reply to: HELP !! Farmall M won't stop overheating! posted by Farmall Daddy on May 14, 2003 at 14:33:52:
Wemt through the same thing,nearly,as your going through.First thing Iwould do is get it warmed up with the rad cap off and make sure water is flowing good.You didnt say but is it accually spewing out or is it just getting real hot.Could be a defective thermostat or if you lucky the gauge is bad.NEw things can go bad.Another thing is when you say you bored it,did you accually bore it or just go with a bigger piston and sleeve.If you bored it you may have go too far with it and ruined the block.My problem was a big glob of solder,which i think may have come from the new rad I installed,had almost completely block the metal part of the lower radiatior hose and i just missed it.I accualy had to pull out my little torch and melt the solder out.
Post A Followup
: Re: Re: HELP !! Farmall M won't stop overheating!
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
