Re: Super A head gasket, which one to buy
Posted by Stan(VA). on August 02, 2004 at 05:34:31 from (208.59.156.134):
In Reply to: Re: Super A head gasket, which one to buy posted by bryan meade on August 01, 2004 at 19:05:45:
Bryan,
Depending on which engine block and what sleeve kit is in there at the moment it could be 113, 123 or 133 inches. But for the sake of ordering the head gasket it's a C113. Like Justin said, the difference is the water pump (C113's came w/o, C123's came with). Either gasket will fit, but the C113 (w/o pump) has larger water jacket openings to allow the thermosiphon system to work; the C123 (with pump) has smaller water jacket openings to restrict flow. Danger is obviously putting a C123 gasket on a motor w/o the pump, then trying to work it hard. Either way, if you have it apart try to flush as much sediment as poss out from around the sleeves.
Stan(VA).
Post a Followup
Subject:
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
