Re: S/M 12 v Conversion
Posted by Nat on December 08, 2005 at 10:57:42 from (64.80.108.52):
In Reply to: S/M 12 v Conversion posted by Lerm on December 08, 2005 at 10:13:35:
Bob M's diagram MIGHT help, but it's probably similar, and similarly confusing, to the diagram that came with your kit. Unfortunately, there's no "universal" way to convert to 12V, and without more information from you, there's absolutely no way to break it down "Mr. Potato Head style" for you. Who's kit did you get? What did it come with? The basic steps are: 1. Remove 6V battery, 6V light bulbs, voltage regulator and generator. 2. Install alternator, fabricating new bracketry or modifying the existing bracket as necessary. 3. Install 12V light bulbs. 4. Install 12V battery, attaching the - terminal to the tractor frame. 5. Wire it up, which could be a couple different ways depending on the alternator you have. If you've got a one-wire alternator, you're on easy street. All you need to do is run a wire from the terminal on the alternator back to the battery's + terminal. If you want to do it right, you can run the wire from the alternator to the starter switch, connecting to the main cable that runs back to the battery. Other connections: 1. Battery + to on/off switch, then on/off switch to the coil. If you want to do it right, you can run the wire from the main battery cable on the stater switch to the on/off switch. 2. Battery + to fuse, then fuse to light switch, then light switch to lights. If you want to do it right, you can run the wire from the battery side of the on/off switch instead of running a separate wire from the battery. 3. Battery + to starter switch, with heavy 2 or 0 gauge cables. If you need the tractor now, put it back the way it was and use it.
Home
| Forums
Today's Featured Article -
Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli
... [Read Article]
Latest Ad:
1945 Farmall wide body gas with pto and front plow. Runs good but needs new points.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
