Re: S/M 12 v Conversion
Posted by Lerm on December 08, 2005 at 11:43:46 from (209.222.248.177):
In Reply to: Re: S/M 12 v Conversion posted by Nat on December 08, 2005 at 10:57:42:
The conv kit I ordered right off this website, Tisco is the only info on the box. What came with it was Bracket, Alt, wiring harness, resistor, I'm having problems with the harness and where to connect into the fuse box ?, I removed old wiring and I don't wan't to burn up the alt by making the wrong connection. The alt is not a one wire alt it's got connections on top for two wires and one in the back. Here's what the inst say ?
A. #10 short red&white wire- AMP meter neg
- side to starter switch (battery side)
B. #10 RED WIRE- AMP meter positive + to alternator battery terminal main harness
C. #14 red short wire either term on amp meterto battery on ignition switch.
D. #14 brown wire ignition switch Term marked IGN to coil resistor main harness
E. #14 blue wire - Resistor to coil (battery side + coil Neg to dist.
Today's Featured Article - The River Tractor - by Charlie English Jr.. This is a 4010 John Deere that was used to farm on the Diamond Island which is in the Ohio River about 15 miles southwest of Evansville, Indiana. About ten years ago, this tractor was parked close to the bank as the river was washing the bank of the island away. ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
