Re: Farmall A Cooling System
Posted by mbnok on August 06, 2006 at 19:39:21 from (216.226.31.40):
In Reply to: Farmall A Cooling System posted by Brad T on August 06, 2006 at 18:21:19:
The radiator could be stopped up, but, a thermo syphon system operates on its own at about 180 degrees. So there has to be sufficent expansion room in the upper radiator tank. The radiators had what appeared to be a tube down into the tank and the water level was to be about half way up in there. Then when you looked in there at operating temp the water would be raising and falling, and it would gurgle and make noises running or not. Don't add water until it gets down to the tubes, and if it gets down to the tubes pretty quick you probably have stopped up radiator.
Today's Featured Article - Tractor Profile: Allis-Chalmers Model G - by Staff. The first Allis-Chalmers Model G was produced in 1948 in Gasden, Alabama, and was designed for vegetable gardeners, small farms and landscape businesses. It is a small compact tractor that came with a complete line of implements especially tailored for its unique design. It featured a rear-mounted Continental N62 four-cylinder engine with a 2-3/8 x 3-1/2 inch bore and stroke. The rear-mounted engine provided traction for the rear wheels while at the same time gave the tractor operator a gre ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
