Hydraulic Help Please
Posted by Brian Jensen on October 04, 2007 at 12:26:37 from (207.176.229.92):
I have been running the old girl for about an hour now filled the hydraulic reservoir up to the bottom of the fill hole opened what I think is the bleed valve (hex key bolt above and slightly forward of the distributor, it looks to have hydro fluid in it) I have been cranking (armstronging) the wheels back and forth and pushing and pulling hydro levers and I have not even had a hiccup yet out of it. What am I doing wrong? I know in the thick german accent of the previous owner I was told (warned) about how hard it is to get it primed again. But an hour seems a bit excessive, it doesn't even seem like it is trying. below my steering wheel there is a lever that I disconnected when I pulled the instrument cluster to repaint it but I put it back on, I am assuming that this lever turns the hydraulic pump off and on? I have a Du Al Bucket and Grapple on it so my hydraulic levers are all aftermarket mounted to the rear passenger side fender. Is there a way to expedite this process? Or should I be doing something differently? I cannot handle a 10 month process of getting the hydraulics to work, they did work when I parked the tractor 10 months ago, but there was a leak on the power steering lines, would it help if I used a jackall to lift the bucket and then I let it back down would that give me enough pressure to get the fluid moving?. Any ideas are always appreciated. I also have to mention that I think the only person more excited than me was my 3 year old boy, he has wanted to go for a ride on that thing everyday for the past 10 months, and now he wil finally be able to. :)
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
