I personally would not go to a distributor set up, I like the mag, the fact, if battery is dead, crank will start it, or you can pull it to start, mags are not a scarey as people make them to be, they are very simple to work on. They seem to be a lot more reliable than battery ignition. My m had a distributor, that is now on the shelf, every time I went to use it, I had to file the points or fiddle with it, I have mags on all my tractors, and I have not touched them since I put them on. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
