The one for a H is somewhat hard to find. It will work on both a H & Super H.
You can use the orginal cam gear with one of these pumps, BUT if you do remember that you CANNOT deadhead or bottom out the pump. If the pump is deadheaded or bottomed out there is a chance that the cam gear could fail.
I had a company named Hi-Low rebuild one a few years ago. If I remember right it cost about 175 to have it rebuilt.
The pump for the H model has 24 teeth on the drive gear, and the pump for the M has 27 teeth on the drive gear.
Sometimes "Steel Wheel Ranch" has these, I don't know how much they sell them for.
The M&W Live pump pictured bellow is for a M, but the one for a H looks the same. The difference in them is in the number of teeth on the drive gear and the bolt pattern.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
