1. You need the right H. It has to have been made after mid-1950, or it doesn't have the right front engine plate or the upgraded timing gears to handle a live pump. Live pumps won't fit on older Hs without changing the front engine cover and timing gears.
2. You need a live pump for a Super H, 300, 350 (gas). These cost about $600 new. Used pumps are less expensive, but they are not rebuildable if you get a bad one.
3. You need a reservoir. Many people disconnect the stock belly pump and use it as a live reservoir. It only holds 6 quarts of oil, though.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
