Mkirsh, I have seen this topic here countless times and I guess it will never be settled as long as there are still two H's left. I put a live pump on my 41 H about 1968, did not change any gears or cover, two bolt holes match, drilled and threaded a third hole and made a simple clamp for the fourth. It has run hyd. motors, a Dacon reel type rock picker, a 2001 loader along with many other jobs, totaling several hundred hours each year since. I used the transmission as a resivoir. I have done absolutely no repairs to it in all those years. So I guess I am here to say it foolish to change the cover or gear. Chuck
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
