Posted by mkirsch on August 07, 2008 at 11:09:02 from (64.80.110.50):
I'm getting a little frustrated here.
Twice now I've set out to install the expensive new battery box parts I bought from OEM on my Super A in the hopes that it will help to firm up the slightly wobbly steering post. Twice now I've been sent packing with a black eye and my tail between my legs...
Both blind nuts are stripped out. I was able to slip a nut behind one, and rethread the other with 3/8 NC.
Had the box almost installed, but now the battery won't clear the bolts! I can install the right panel, wedge the battery in, but now I can't get the bolt into the instrument panel on the left side because the battery is too tall...
I guess this is why most Super As I see don't have any battery box at all...
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
