Posted by SuperA-Tx on August 07, 2008 at 12:10:11 from (4.226.54.206):
In Reply to: Super A Battery Box posted by mkirsch on August 07, 2008 at 11:09:02:
The battery box sides are a little differant than the originals but they will work if you ordered both sides. The top is correct from OEM but the little clips on the sides are down further than the original. The top is correct enough to work but you might want to cut a little off the T bolts where it doesnt stick up as far.
A 12V battery will fit in the box just fine. You just need a differant battery. Take the battery box width, length and height measurements and buy a new battery that will fit.
Another problem your going to see is that the battery post is going to be close to the "blind" bolts. Wedge some rubber or wooden wedges in there to make the battery tight.
One other thing you might want to address now is that the battery is going to ride on the lip of the battery box. Cut a 1/4" piece of wood and lay on the bottom to make it flat. Cut it wide enough to fit between the battery lip/side and that will bring it up even.
BTW - I just got a new battery box lid from OEM and put it on this morning. Had one off a 140 on there but the metal clips under the lid kept getting in the way.
Today's Featured Article - A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
