Posted by tipper on March 06, 2009 at 18:40:22 from (75.88.240.252):
So what valves misbehaving can lead to the PTO being on all the time? If the PTO is staying on (and the MCV plate gasket is known to be good), what must be open and allowing pressure to get to the PTO port? I can disconnect the linkage completely and the PTO stays engaged. I have removed the pto valve from the MCV, and I did not notice any problems. I'm not saying there isn't a problem, but the valve moved freely. I am contemplating hooking a gauge up to see exactly what kind of pressure I have while it is "off" and still turning. As I said before, you can hear something different going on when the PTO is officially engaged--this would lead me to believe that the pto valve is opening more (and it is not a straight and full flow leak), but can a leak on that valve in the closed position cause this? Are there any remedies for a valve that leaks--I only see two o-rings in the breakdown, and I doubt either are in "keep the pto from turning" places.
BTW, I'd assume a stuck flow divider valve would keep something from working--not keep something from turning off.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
