Re: Farmall H low oil pressure problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on April 11, 2000 at 01:46:33 from (12.75.196.28):
In Reply to: Farmall H low oil pressure problem posted by Jim Radley on April 10, 2000 at 19:50:34:
Jim if the rods are tight on the journals, it doesn't use oil and is running good, I really doubt the bearings need replacing. But if you do replace them, the job is pretty easy.
Post A Followup
: Re: Re: Farmall H low oil pressure problem
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
