Farmall H low oil pressure problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Jim Radley on April 10, 2000 at 19:50:34 from (207.218.83.156):
I posted a question about an old Farmall H that I am restoring yesterday and I thank all who responded. I do have another question though. I have a problem with low oil pressure after the engine warms up. I am looking at the oil pump now but I had a friend tell me that if the main bearings were bad that they would also cause low oil pressure and that if I already had the pan off that I should go ahead and replace the rod and main bearings. Should I go ahead and do this? The engine does run great even with the low oil pressure and has no noise. I don't know the history of this tractor and I'm not a professional mechanic, I could use some more advise from all you great Farmall fans!!
Post A Followup
: Re: Farmall H low oil pressure problem
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
