Posted by Janicholson on May 24, 2009 at 21:17:42 from (66.173.50.171):
In Reply to: 1951 FARMALL C posted by burnsg on May 24, 2009 at 20:54:23:
A warped gasket seating area can cause leaks. Check carefully to see where it leaks from. If the bowl seal, flat sanding it on glass with 320 paper will get it straight. Look at the gasket to see if some areas are pinched while others are not. JimN
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
