Re: Dreaded Antifreeze in Oil
Posted by Janicholson on May 25, 2009 at 08:18:57 from (66.173.50.152):
In Reply to: Re: Dreaded Antifreeze in Oil posted by Larry Hardesty on May 25, 2009 at 07:56:11:
The radiators can only stand 7psi (do not use more)the tank metal will break at its seams.
I also believe the Orings are probably at fault. I believe that A treatment with ground black Pepper (about 1/4 cup), or Bars Leak can seal up leaks permanently. It is worth a try and cheap at that.
JimN
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
