Thanks for your explanation of the Farmall M hydraulic system. Now I have several more questions;
1. Since this is a one-way system, I assume the right and left hydraulic ports connect to two seperate cylinders. Both cylinders would raise by hydraulic pressure and lower by gravity?
2. In taking a closer look, I noticed there is a 1/2 inch threaded connection just below and slightly to the front of the right side hydraulic connection. It appears to be plugged with dirt and grease. Any idea what this is for?
3. As for the hydraulic control lever, I'm not sure it's working properly. With engine off, the lever is resting in the forward position. Pulling it back towards the steeing wheel it pivots about 20 degrees until it hits a stop. When released it flops back to the forward position. I don't sense any stop or detent to hold it in the middle position. Is this normal?
4. What are the requirements for hydraulic fluid, how much and what is the proper fill level? Also, should the system be flushed before filling?
5. Is there a good way to tell if the hydraulic system is working without investing in lots of expensive equipment?
6. If adding a 2-way valve to make it a two-way system as you described, I assume that would mean hydraulic connections to both ends of the cylinder(s). If so, doesn't there have to be a return path from the 2-way valve back to the reservoir and if so, how would this be implemented?
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
