The rod that controls the Liftall passes through a slot like cast arm on the steering post. This bracket is used to hook the rod in the hold position. The small welded on stop on the under side of the rod is hooked on the slot in the bracket. (there is supposed to be a flat spring on the bottom of that slot, that holds down on the rod but many are broken) The rod pulls farther to lift, and back to the stop to hold, and lifted and pushed farther to lower the load. I am concerned about the rear left outlet. It should be able to be tightened into the housing (inside) to prevent leakage. it is just Pipe thread. If turning it CW never tightens it, the pump will need to be removed to fix the threads. It is under pressure when the rod is pulled (delayed, but still pressurized. The pump comes out easily (but awkwardly) out the bottom. The cover plate is removed, the cotters in the pump drive shaft removed, then the drive shaft. The pipe fittings and cap and lever are removed, and the 4 bolts holding it up are loosened, not removed until ready. The pump is heavy and needs a floor jack, and two people to lower it. Threaded rod in the bolt holes and nuts to lower it are slower, but safe. JimN
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
