Posted by Fawteen on August 04, 2009 at 14:59:31 from (72.95.100.81):
In Reply to: Re: F 14 fuel system posted by Dave Allgire on August 04, 2009 at 11:59:46:
Actually, I think you'll find that if the float is waterlogged (full of gas) it will sink and OPEN the fuel inlet, causing flooding. I had that problem with mine.
Unless you're killing the tractor by turning off the fuel and letting it run until it stalls, there should be gas in the carb even after it's been sitting for a few days. If it's dry, you have a leak somewhere draining the fuel out of the carb bowl.
If the carb is dry after cranking, you have a fuel inlet problem, either the float/needle assembly is sticking, the inlet filter is partially plugged (as it will start/run when pulled, it can't be completely plugged) or the fuel pump is too weak to push fuel past the filter at hand-cranking speed. When you pull it, the engine is turning over faster, running the fuel pump faster.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
