560 farmall ring and pinion is a 3.26 to 1 ratio, SMTA, 400 and 450 is 2.63 to one. Unless you have a early 560 that the differential was never upgraded in put the 400 ring gear on the 560 differential. On the pinion shaft you need to use the 560 rear bearing and bearing housing on the 400 main shaft, unless its a early 560 tractor with a 3 bolt bearing housing instead of a later 4 bolt.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
