Re: Stanadyne injection pump question
Posted by Bob on September 16, 2010 at 12:01:50 from (69.178.228.68):
In Reply to: Stanadyne injection pump question posted by Tom/Idaho on September 16, 2010 at 11:23:01:
Having a flow of fuel at the fuel return fitting AND having the fittings on the injection lines "cracked" loose should allow the system to bleed.
Sometimes it takes a while. If you can have a helper pull the tractor around a bit it will save in the starter.
Otherwise, the metering valve and/or the pumping plungers in the IP MAY be stuck.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
