Stanadyne injection pump question
Posted by Tom/Idaho on September 16, 2010 at 11:23:01 from (216.57.174.229):
656 sat for about 6 months while all the fuel drained out of a small hole in the bottom of the primary filter. Replaced the filter canister and bled the tops of both filters and have fuel coming out the return line in top of pump. Can get only a few bubbles out the injector lines at the injectors. Will not take enough fuel to the injectors to start. Will only fire a time or two on very small shots of ether. Owner says it ran fine when shut down 6 month ago. Is there a bleed screw on the injection pump?
Any suggestion will be appreciated. Thanks, Tom/Idaho
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
