The pump is supposed to be self-bleeding, thus no bleeder screws. That only works though if the fuel going into it is 100% air-free.
Keep in mind that the pump only runs at 1/2 engine speed, so an engine cranking at a normal 400 RPM is only turning the injection pump at 200 RPM. When a pump has some wear, and/or is a bit dried out, sometimes getting the cranking speed up will make a huge difference. Stanadyne pumps have their own rotary transfer pump built into the back of them. Those pump vanes are often the first thing to wear and cause starting problems after an engine has sat. That is especially true when run on low-lube diesel (miltary and some versions of low-sulfur at the pump).
Try hooking some extra batteries to the tractor (in parallel) and see if you can get your cranking voltage up. Even if it jumps from 9 volt to 10 volts, it will crank MUCH faster.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
