Re: farmall 560 problem
Posted by rustyfarmall on December 03, 2010 at 06:47:20 from (209.152.78.140):
In Reply to: farmall 560 problem posted by luv2wrench on December 02, 2010 at 18:30:02:
It is the carburetor. Probably needs a thorough cleaning and rebuild, but you might get by with just a new float valve and a gasket set. Might also need to remove the fuel inlet fitting and clean the strainer, and while you're at it, clean the sediment bowl under the gas tank. If you've never has a carburetor apart, you might want to get an I&T manual and study it, or get someone with experience to help you.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
