Re: Looked at tractor today...generator problems. Expensi...
Posted by farmallhal on December 05, 2010 at 19:11:55 from (76.2.182.168):
In Reply to: Looked at tractor today...generator problems. Expensive?? posted by RTR on December 05, 2010 at 18:55:39:
I'm not an electrical expert here but I've run into the same problems and it is usually the connections somewhere between the battery and the starter. Start with making sure you have heavy gauge battery cables between the battery and starter as they should be 00 in size. Any good auto parts store can make them up to the correct lengths with soldered terminals. Run the ground directly from the battery to a starter to frame mounting bolt. Make sure all your connections between the battery, switch and starter are all clean, bright and tight. The charging or lack of will be addressed by others using Bob M's or John T's troubleshooting guide as they have been posted on this forum at least weekly, Hal.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
