Looked at tractor today...generator problems. Expensive??
Posted by RTR on December 05, 2010 at 18:55:39 from (74.248.177.174):
I went and looked at a Farmall Super A with the 6 volt generator (picking it up tomorrow actually). It had the voltage regulator (square box) mounted on top of it. When I started the tractor it seemed like it barely had enough power to start it, and if the tractor didn't run so well, it wouldn't have. There is an 8 volt battery (which I would think would have more power than a 6 volt battery), and it just seemed WAAAY too weak to me. While it was running, the ammeter read on the negative (left) side, and read around the -10 mark on the left side.
Otherwise the tractor has been "restored" and is flawless otherwise. A local guy that specializes in Farmall offset tractors has it. What am I getting into, and how much will it cost to fix approximately. THANKS.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
