Answer is "it depends". Best case scenario is a battery charge (free) and perhaps a new voltage regulator ($40).
More likely however you will also need a new 6 volt battery, voltage regulator and new heavier, battery cables - about $150 or so.
And if the generator is bad, a rebuild will run another $100 - $125.
Incidentally I would replace the existing 8 volt battery with a new 6 volt regardless. Over the long haul it will cost less to find/fix the problem that caused the previous owner to install an 8 volt battery in the first place!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
