Re: Farmall B Cultivator- Urgent
Posted by Janicholson on March 14, 2011 at 13:56:43 from (199.17.6.194):
In Reply to: Re: Farmall B Cultivator- Urgent posted by sflem849 on March 14, 2011 at 13:27:05:
That front axle has been damaged by running into something. The spindles need to be just a little forward of straight up and down. They are now backward of up and down. It will steer much more accurately if repaired. Adaptive modifications are going to be needed to make any cultivator fit and work correctly. Belt driven Hydraulics are much better. Jim
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
