Re: generator rebuild
Posted by The Red on July 23, 2000 at 09:59:42 from (12.75.197.145):
In Reply to: generator rebuild posted by Aaron on July 23, 2000 at 09:41:48:
Yes the generator off the M will work on the H. Any good alternator shop can rebuild the generator or even upgrade it to 12 volt if you desire. Depending on what is all wrong with the generator, a professional rebuild will run between $50-75. A new Delco voltage regulator will run around $50 if one is needed.
Post A Followup
: Re: Re: generator rebuild
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
