Axle Spindle Spline Problem/Solutions for 664/656
Posted by BMD on March 18, 2012 at 19:19:51 from (24.125.139.102):
We have a 664 on the farm that the spindle splines are worn causing steering problem. The spindle nuts are tight as possible and still have way to much play.
The 664 has basically the same wide front as 656 utility, only real difference is the 664 is D-239 powered. It is still a great running straight tractor that tough as nails,just no where near a beauty queen.Perfect tractor for turning 6ft high briers and scrub into a beautiful field.
The 664 is used mainly used as a mowing tractor a couple times a year these days.
Been researching this forum for solutions and have 5 possible solutions. I"ll list the below. I would appreciate it greatly if anyone with experience with this problem would chime in with their advise.
Here we go.
1-Buy new spindles and steering arms. I try to always to fix things "right" but since its not my personal tractor and used couple times a year this probably would be overkill if a suitable repair is available.
2-Weld the spindles to the steering arms. Only down side is that"s a pretty drastic solution.
3-Use JB Weld or other liquid metal product on spindle splines, reassemble and let it cure a week or so before using. Not sure if its strong enough to handle the loads at the spline/steering arm interface. Also,sort of semi-permanent.
4-Use shim stock between splines and arm. Then tighten nut down good. Maybe good starting point since its not permanent before moving on to other choices. Question on type shim stock. Looks like my choices are shim stock are stainless,steel and brass. Which would work best for this?
5- Drill through arm and spindle and drive in 5/16 pin to lock them together.Possible downside is the spindle probably going to be pretty near impossible to get a hole through.
Thats all the options I can think of.
If someone has any experience or advise with any of these solutions,your comments pro or con would be greatly appreciated.
Thanks in advance
BMD
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
