Posted by DeltaRed on March 19, 2012 at 19:44:54 from (71.208.14.2):
Where is the correct location ,before the turbo or after the turbo?The 706(310) has the probe before the turbo.It also has manifold boost pressure gauge.During normal farming operations,it runs between 1000 and 1100 degrees and between 10 15 lbs boost.sometimes on the 'tough spots',the temp will go over 1300 and 20 lbs boost.I shift down(TA)when this happens.Is this too hot?Its been that way for 20+ years.If the temp probe was after the turbo,would the temp read lower?Does the probe placement reall matter?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
