You can change out that seal with the belly pump still in the tractor, but it is so much easier if the pump is removed. Well worth your time to do it.
Farmall Hs are rather cold blooded, and the hesitation MIGHT be just because the engine is not warmed up enough. If that is not the case, then I can recommend making sure the carburetor high speed idle adjustment screw is a minimum of 3 turns out, and if that does not help, then there is still some crud hiding deep down in the carburetor.
Today's Featured Article - Fabricating Sidesheets - by Chris Pratt. The easiest and best first-time project for wanna-be sheet-metal workers like myself is flat or nearly flat metal cut and drilled to be a tractor's sidesheet. A sidesheet is sheetmetal to cover either the engine as in the case of early Oliver's, Massey-Harris' and many crawlers or the wiring and electrical components as in the case of the Massey-Harris Pony, Allis Chalmers' D Series (D-14, D-15, D-12, D-10, D-17, and D-19). The need for fabricating becomes obvious when you go to buy any of these
... [Read Article]
Latest Ad:
[More Ads]
