H idle to wide open throttle and belly pump issue
Posted by gary in neb. on March 20, 2012 at 06:17:34 from (24.116.17.253):
Hi all, got an H i'm working on after the owner could not get it to run. put gas in, and wow, it runs, BUT when going from idle to WOT you have to go pretty slow or it will die, like lack of fuel maybe? or is that a timing issue. took carb apart, cleaned it up. idles great, WOT great, just going from one to the other.
also noticed the rear seal of the belly pump, where the trans shaft comes through is leaking. can i change that in the tractor by removing the coupler?
thanks
Gary
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
