Re: Re: I Never Thought Of This!!!
Posted by A 6v Generator! on September 17, 2000 at 07:43:07 from (207.254.53.56):
In Reply to: Re: I Never Thought Of This!!! posted by A Wattage Machine... Nothing More!!! on September 16, 2000 at 21:24:45:
Hi All, I thought someone would like to know what happens when you use the same generator on a 6v system so I'll continue with the same example as before:
Consider a generator with a "rated" output of 13.6v @ 65amps = 884 watts with a 12v voltage regulator and a 12v battery.
That same generator will have a output of 884 watts at 7.2v@122.8amps with a 6v voltage regulator and a 6v battery.
As you can see the amperage output is nearley doubled because the voltage is half of the rated input.
Now you can see why generators are rated in watts rather than amperage. If we try and control the amperage for regulation we would have some very heavy duty controls but voltage is only a "potenial" or assumed "force" therefor it's very easy to control output with small voltage controls and low "control" amperage.
T_Bone
Post A Followup
: Re: Re: Re: I Never Thought Of This!!!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
