Re: I Never Thought Of This!!!
Posted by A Wattage Machine... Nothing More!!! on September 16, 2000 at 21:24:45 from (207.254.52.192):
In Reply to: I Never Thought Of This!!! posted by Bill {Antique Acres} on September 16, 2000 at 16:08:12:
Les is correct. A generator or alternator is nothing more than a wattage machine.
Consider a generator with a "rated" output of 13.6v @ 65amps = 884 watts with a 12v voltage regulator and a 12v battery.
That same generator will have a output of 884 watts at 19.8v@44.5amps with a 18v voltage regulator and a 18v battery.
That same generator will have a output of 884 watts at 26.4v@33.5amps with a 24v voltage regulator and a 24v battery.
That same generator will have a output of 884 watts at 39.6v@22.3amps with a 36v voltage regulator and a 36v battery., etc.
The voltage regulator controls the field voltage to the generator thus regulates the amperage output. But the generator is still only rated at 884 watts no matter what voltage is input.
Thats why it's called a voltage regulator folks!!!
and is a self excited generator.
T_Bone
Post A Followup
: Re: Re: I Never Thought Of This!!!
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
