Posted by Phil Eastman on March 25, 2012 at 19:43:46 from (98.194.78.108):
I recently bought a 1941 Farmall A that has the distributor cap off and some of the parts to the magneto. I haven"t pulled any other parts off to look at the points. The tractor has been sitting in a garage for the last 5 years. I did pull the plugs and squirted MMO into the pistons and used the hand crank to turn it over. I will drain the crankcase and change the oil filter. I have the original owner"s manual and the parts manual. I need to know what my next step should be since I have had little experience with a magneto. I would presume the timing is off so what should I do to get this tractor running? Thanks in advance for your expertise.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
