Posted by El Toro on March 26, 2012 at 04:31:45 from (108.3.225.57):
In Reply to: Farmall A Magneto posted by Phil Eastman on March 25, 2012 at 19:43:46:
Remove No1 sparkplug near the radiator and hold your thumb over the plug hole while a helper slowly cranks the engine until you feel pressure against your thumb. Then drop a long plastic straw on top of the piston then you watch the straw rise while your helper slowly keeps cranking. When the straw quits rising No1 piston should be at TDC on the compression stroke. Then see where your rotor is pointing if it has one. It should be pointing to your No1 plug tower on the cap. That's at 1 o'clock. If your mag is missing the rotor buy one and then see if it's pointing to the No1 plug tower. If you pull the mag when No1 piston is at TDC THEN DON"T MOVE THE ENGINE until you have the mag installed. You still need the rotor at 1 o'clock before installing the mag. Hal
Today's Featured Article - A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
