Re: No start A Farmall
Posted by JRSutton on May 25, 2012 at 15:42:22 from (75.130.109.233):
In Reply to: Re: No start A Farmall posted by Gordoro on May 25, 2012 at 12:26:28:
Unlikely that it's an issue. Hard to build up vacuum at slow speed with the open carb sitting right there.
But you can try to feel for vacuum over the face of the carb's inlet. Might be more accurate at slow starter speed.
If there truly is no vacuum - you've got to look for a leak in the manifold connection.
It can happen, but I'm still thinking it's much more likely a problem with the carb. Either blocked internally - or flooding.
Does it drip gas at all? if so that hints at flooding.
However firing only with starting fluid hints that you've got gas blockage.
Personally I'd focos on that angle. Remove the carb and clean everything.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
