Re: Starter wiring for an A
Posted by mkirsch on June 27, 2012 at 06:31:17 from (64.80.110.75):
In Reply to: Starter wiring for an A posted by charlie M on June 26, 2012 at 16:53:09:
How do you want it wired?
Do you want the solenoid incorporated, or do you want to go back to an original style?
The solenoid is/was up under the tank, so you have a starter with a threaded stud, correct?
The simplest way to set it up is to get one of those heavy pushbutton switches and mount it somewhere convenient. Install the battery. Connect one post of the battery directly to the tractor's frame. Connect the other post to one terminal on the switch. Connect the other terminal on the switch to the stud on the starter. Push the button. VROOM!
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
