Farmall M Hydraulic Pump out put shaft seal
Posted by Peter Hendrickson on October 07, 2012 at 17:12:45 from (97.83.157.85):
anyone tell me how to get the coupler off that hooks to the hydraulic pump in the belly of the M so that I can get the seal out of the housing that is leaking? tried a small gear puller and the thing wont budge.
Thanks in Advance
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
Latest Ad: 1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen [More Ads]
