Here is a picture of a tool made for removing the drive nut. With the tractor in high gear and the brakes set you can unscrew the drive nut from the tramission counter shaft. With the square key of the tool in the slot of the nut, as you put a little pull on the tool take a hammer and tap on the nut.
I also have a tool made for removing the nut from the pump, but I can't find the picture. I took an old inpact socket that I welded a piece of key stock to that fits the nut and with the air impact wrench I have been able to remove the nut from the pump without any disassembly of the pump assembly.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
