I don't know of any place to download a free manual. Printed ones are $20-$30. Do yourself a favor and buy one. It's a mere fraction of what you spent on the tractor.
Did you turn the fuel on before you tried to start it? If not you ran it out of fuel and now you will need to bleed the entire system.
With 1/4 tank of fuel the tractor should run on any angle it will sit on. That's not your problem.
Did you run the glow plugs? Do the glow plugs work? Don't use ether on glow plug engines.
There is air in the steering now due to the leak and you trying to steer it without the tractor running. It may clear up once you get it running.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
