Re: finally got me a big tractor
Posted by Ed3 on April 08, 2014 at 15:36:57 from (70.192.80.8):
In Reply to: Re: finally got me a big tractor posted by mkirsch on April 07, 2014 at 09:49:32:
I second the ether comment. Don't do it on a glow plug engine
bad things could happen
Those old engine need good working glow plugs and they take
a while to Heat up . Not like a modern tractor that only
requires less that 30 seconds.
Once hot they start fairly easy. If they are marginal in any
way you'll crank it to the cows come home and it won't start
Their are some Manuel's on this site, eBay or even the local
oh dealer
Change the filters, bleed the system and make sure the glow
plugs are in tip top shape .
Get the biggest battery you can as one battery is better than
the 2 battery system it had. One battery has less terminals
Carquest has a 1200 amp jumbo car size battery that should fit
by the seat
Good battery clean filters and good glow plugs and your
starting problems will be gone
Good luck with it
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
