1953 Cub back fire
Posted by Gary McArdle on June 02, 2014 at 20:34:58 from (75.121.246.13):
Had no spark at plugs. Install a tune up kit including distributor cap. Had to remove distributor to install point and condensor. Now have spark at all spark plugs. Still want start but back fires once in a while. Marked the distributor and very carefully put it back. Help!
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
