Re: 1953 Cub back fire
Posted by El Toro on June 03, 2014 at 05:57:07 from (96.244.7.206):
In Reply to: 1953 Cub back fire posted by Gary McArdle on June 02, 2014 at 20:34:58:
You need to remove the sparkplug near the radiator
and bring that piston to TDC on the compression stroke.
You will need a helper crank the engine and you hold your thumb over the plug hole until you feel compression and the helper slowly keeps cranking until that piston is at TDC. You can drop a long plastic straw on top of the piston if possible and watch it rise. Then look at your rotor to see where its pointing. Should be at the No1 plug tower. If it's off remove the distributor or mag and rotate it so it's aligned
with the No1 plug tower and reinstall it. Hal
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
