Thinking about getting a new tractor
Posted by JRSutton on July 07, 2014 at 10:43:42 from (71.174.108.252):
Would be used 100% for haying (small square bales).
pulling a haybine mower (which I don't own yet) - and a jd 24t baler dropping on the ground, no wagon attached.
Might want something to occassinoally pull a discbine, but thinking probably not since I don't want to spend more money for the extra horsepower on this one. (but since I don't really know what models to look at - not sure if it'd be a possibility - discbine needs a minimum of 90hp. assuming I won't want to buy something that big)
Areas we do are fairly hilly so we drop them on the ground.
I need something that'll EASILY handle the weight of the baler and or full wagons on the hills (nothing too radical, but some are enough to make you a little nervous going down with a full wagon behind).
I've used an M for years (and I'd call it a little on the light/underpowered side), alos use a JD 630 which feels closer to appropriate.
I like live pto.
I'm just not familiar with anything farmall after the 350/450 series.
560 - etc.
I'm not sure how the numbers even run from that point in history.
I know it's a very subjective question - but if you had to buy one do-it-all haying tractor (this one would do about 3000/4000 bales/year - don't ask me the acreage, lots of small fields)
And money was a prime concern...
What would you pick? Anything to avoid. I know the 560's had some rearend strength issues...
would like to hear other's opinions.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
