Re: ballast resistor/ IH 184
Posted by pilot199 on July 24, 2014 at 00:10:40 from (184.46.45.90):
In Reply to: Re: ballast resistor/ IH 184 posted by Owen Aaland on July 22, 2014 at 21:07:08:
Owen, I checked & you are right, the tractor
now WILL NOT shut off by turning the key.
I didn't notice it at first because I only use the
tractor every 10 to 12 days so I turn the gas off
until it kills. Our humidity is so high down here &
I find this helps minimize carb problems on a
sitting tractor.
The new 2 ohm resistor is wired exactly like the
old one, which is to say that the lead leaves the
resistor & runs down to the positive side of the
coil. I believe that is also how the schematic
shows it as well.
How can I get this thing to shut off by the key &
still charge the battery when running?
Gary
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
