Go back to a 25 ohm resistor. If you are sure your old resistor has the correct ohm reading,put it back in and see if it works.
Does this tractor have an ignition resistor between the switch and coil? If you are running 12 volts directly to the coil without any resistor a 25 ohm resister should work without any problems. That is the system that IH used on their diesel tractors when using a 10SI alternator. Many of the tractors with gas engines used a diode instead of the resistor. If yours will not work with the correct resistor you could switch a diode.
One other possibility is that the brushes are getting worn in the alternator. If the alternator uses sliding brushes rather than swinging brushes you may have a situation when a brush was hung up enough to cause a poor connection to the slip ring. That could make it not charge. Removing the alternator from the tractor and taking it to be tested may have causes the brush to come free and allow the alternator to begin charging once again.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
